[Ra...] Posted May 1 Share Posted May 1 Has anyone ever used the title name's extension? I found it in the PCM cookbook. It doesn't seem to accomplish what it says it does, or anything for that matter. But I'm also a novice, and not sure if I'm applying it right. every attempt I've made, the "d" is still there. Not a big deal at all, mostly just curious if I'm too stupid to apply it, or if it just doesn't work. Link to comment https://qualityforum.zeiss.com/topic/26512-printstringwithoutexponentf/ Share on other sites More sharing options...
[An...] Posted May 1 Share Posted May 1 Capitalize the 'W' and it should work -- .printStringWithoutExponentF Could also try .asNumeralString and .decimalString 2 Link to comment https://qualityforum.zeiss.com/topic/26512-printstringwithoutexponentf/#findComment-149980 Share on other sites More sharing options...
[Ra...] Posted May 4 Author Share Posted May 4 .... I honestly can't believe the official cookbook has that severe of a typo. Works perfectly with "without" capitalized. Those other two are great as well. Thank you. Link to comment https://qualityforum.zeiss.com/topic/26512-printstringwithoutexponentf/#findComment-150036 Share on other sites More sharing options...
