Hello,
           You may want to check out the tech guide articles below regarding breaking up your measuring volume to measure multiple parts at once.
https://techguide.zeiss.com/en/zeiss-inspect-2026/article/cmd_atos_create_cuboid_working_area_partition.html
https://techguide.zeiss.com/en/zeiss-inspect-2026/article/cmd_atos_create_segment_working_area_partition.html
  • Thank you! 1
https://qualityforum.zeiss.com/topic/26520-pallet-setup/#findComment-150046
  • 4 months later...
Unless I am misunderstanding what you're looking for, I recommend using Autorun.
You can add a pallet of parts, input the XY offset, and run the entire pallet with a few clicks. This allows you to be able to walk away from the machine while measuring a number of parts.
Here is a guide I helped develop in a past job.
AutoRun_Guide_2019 (2).pdf
  • Like! 1
https://qualityforum.zeiss.com/topic/26520-pallet-setup/#findComment-155658
