[Lu...] Posted May 4 Share Posted May 4 Hello, Sorry if this is the wrong forum... Instead of saving as a PDF through piWeb, can I save as a CSV file? I would like to see the same CMM results that I would normally see on my PDF. Thanks, Lukas 1 Link to comment Share on other sites More sharing options...
[An...] Posted May 5 Share Posted May 5 (edited) There are some options for outputting to CSV if you have PiWeb reporting plus. Here is a link on how to: https://portal.zeiss.com/knowledge-base?id=1350161 Edited May 5 Link to comment Share on other sites More sharing options...
[An...] Posted May 5 Share Posted May 5 This method works without reporting plus. You simply modify the report template to include an export option and the exported file looks a little cleaner too with this method. https://portal.zeiss.com/knowledge-base?id=513250 Link to comment Share on other sites More sharing options...
[Lu...] Posted May 7 Author Share Posted May 7 Thanks, I'll give these a shot. So, there is no straight forward way of setting up export to CSV through Multiple Report? Link to comment Share on other sites More sharing options...
[Lu...] Posted May 7 Share Posted May 7 Please sign in to view this quote. Hello, Unfortunately, there is no straightforward way to export CSV files directly from CALYPSO. The closest available option is exporting table files, which are generated in TSV format. Link to comment Share on other sites More sharing options...
