[Ad...] Posted May 7 Share Posted May 7 Is it possible to get the XYZ values of minimum deviation label from a surface comparison? Link to comment https://qualityforum.zeiss.com/topic/26556-pulling-xyz-values-from-minimum-deviation-label-on-surface-comparison/ Share on other sites More sharing options...
[Jo...] Posted May 7 Share Posted May 7 You should find an answer somewhere in this thread 1 Link to comment https://qualityforum.zeiss.com/topic/26556-pulling-xyz-values-from-minimum-deviation-label-on-surface-comparison/#findComment-150248 Share on other sites More sharing options...
[Ad...] Posted May 7 Author Share Posted May 7 Please sign in to view this quote. This is giving me the nominal value of the deviation label, is there a way to pull the measured XYZ value? Link to comment https://qualityforum.zeiss.com/topic/26556-pulling-xyz-values-from-minimum-deviation-label-on-surface-comparison/#findComment-150268 Share on other sites More sharing options...
[Jo...] Posted May 7 Share Posted May 7 Ah ok, i got that mixed up. I think there was a recent thread for that aswell. Link to comment https://qualityforum.zeiss.com/topic/26556-pulling-xyz-values-from-minimum-deviation-label-on-surface-comparison/#findComment-150272 Share on other sites More sharing options...
[Se...] Posted May 11 Share Posted May 11 See also Link to comment https://qualityforum.zeiss.com/topic/26556-pulling-xyz-values-from-minimum-deviation-label-on-surface-comparison/#findComment-150426 Share on other sites More sharing options...
