Hi, RDS-CAA is not supported by the GEAR PRO software. You can use several stylus directions but each has to be a qualified stylus position and stylus number. Regarding gears up on our experience you´ll need max. 8 positions to measure gears with an standard amount of features for a typical gear evaluation.
  • Like! 1
Chris, with XTR it is identical to RDS. You have to qualify the required stylus angle positions as individual stylus numbers of the stylus system. It is not planned to change that behaviour in a future version as most applications are solved by a rotary table system instead of fixed probe or articulating probes like VAST XTR or RDS with VAST XXT.
  • Like! 3
