[Da...] Posted May 12 Share Posted May 12 Is it possible to re-evaluate results in Gear Pro? I ran 2 samples of a part using Involute but noticed I had the wrong tolerance for the dimeter over pins. I updated the tolerance, but would like to regenerate a report. Link to comment https://qualityforum.zeiss.com/topic/26604-re-evaluate-results/ Share on other sites More sharing options...
[Ri...] Posted May 12 Share Posted May 12 Yes. Every run is stored as a .act file in a sub-folder inside the directory your .gear is stored. Open the .act file that you want, change your tolerances and click on the Evaluate button. 1 Link to comment https://qualityforum.zeiss.com/topic/26604-re-evaluate-results/#findComment-150560 Share on other sites More sharing options...
[Ma...] Posted May 13 Share Posted May 13 In addition, you will have to change the tolerance for each .act file you want to evaluate unless this has been changed in newer releases of Gear Pro. Link to comment https://qualityforum.zeiss.com/topic/26604-re-evaluate-results/#findComment-150632 Share on other sites More sharing options...
