[Da...] Posted Tuesday at 08:52 PM Share Posted Tuesday at 08:52 PM Is it possible to re-evaluate results in Gear Pro? I ran 2 samples of a part using Involute but noticed I had the wrong tolerance for the dimeter over pins. I updated the tolerance, but would like to regenerate a report. Link to comment Share on other sites More sharing options...
[Ri...] Posted Tuesday at 09:49 PM Share Posted Tuesday at 09:49 PM Yes. Every run is stored as a .act file in a sub-folder inside the directory your .gear is stored. Open the .act file that you want, change your tolerances and click on the Evaluate button. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 11 hours ago Share Posted 11 hours ago In addition, you will have to change the tolerance for each .act file you want to evaluate unless this has been changed in newer releases of Gear Pro. Link to comment Share on other sites More sharing options...
