Understanding Results on Report
Quick questions on the following acronyms on the attached file called “Gear Report Clarification.png”.  I did look in the help file as well in the presentation you sent us but still can’t find the answer.
  • Est
  • St
  • Wk
  • Eet
  • et
  • FrD
et is the gap width; Eet is the gap width variance.
st is the tooth thickness; Est is the tooth thickness variance.
Wk is the span width; in this example it shows a k value of 2, so a span measurement over (2) teeth.
MrK is the Measurement Over One Ball
MdK is the Measurement Over Two Balls
MdR is the Measurement Over Two Pins
Da is the Major Diameter
FrD is the Runout of the Major Diameter
Df is the Minor Diameter
FrD is the RUnout of the Minor Diameter
