[F_...] Posted May 13 Share Posted May 13 Hello everyone, I have a question regarding the mirroring of nominal, actual, and inspection elements. I am working with a symmetrical component. My goal is to define elements (such as surface points, edge curves, etc.) on one side and then duplicate them to the other side using a mirror function. Current issues: The coordinate system origin is not suitable for this case. Therefore, I created an additional plane, which I intend to use as the reference plane for mirroring. After performing the mirror operation (Element → Mirror), I encounter the following problems: The edge curves parameter can no longer be edited (they appear greyed out). For nominal elements, offset points are converted into simple surface points (see attached image). original: copy: For actual elements, similar behavior occurs—the mirrored elements (e.g., edge curves) are no longer editable. The only approach that works is using the officially provided script "Mirror Evaluation". However, this script only allows mirroring along predefined planes (X, Y, or Z) and not along a user-defined plane. i also tried to change the script code ( replacing the plane) but it did not work. Has anyone experienced similar issues or found a solution for mirroring elements along a custom-defined plane while preserving their properties and editability? Thank you in advance for your support! Link to comment https://qualityforum.zeiss.com/topic/26608-mirroring-nominalactualinspection-elements/ Share on other sites More sharing options...
[Jo...] Posted May 13 Share Posted May 13 Hi, seems to be intended. They differentiate between "Mirror parametrically" and "Mirror geometrically". https://techguide.zeiss.com/de/zeiss-inspect-2026/article/cmd_transform_element_mirror.html#FCT0EJDAE 1 Link to comment https://qualityforum.zeiss.com/topic/26608-mirroring-nominalactualinspection-elements/#findComment-150578 Share on other sites More sharing options...
[Be...] Posted May 13 Share Posted May 13 Hi, you have already given the answer: for arbitrary mirror planes we can't ensure that the parametric is "mirrorable" in (most) cases with the intended behaviour of the customer. This leads to more questions than answers and therefore we prevented this option. Geometrically mirroring is supported with arbitrary planes! Regards 1 Link to comment https://qualityforum.zeiss.com/topic/26608-mirroring-nominalactualinspection-elements/#findComment-150610 Share on other sites More sharing options...
[F_...] Posted May 18 Author Share Posted May 18 Please sign in to view this quote. Thank you for anwser. I understand now that an arbitrary mirror is difficult to achieve in the case of a parametric mirror. Just an idea: would it be possible to temporarily shift (and possibly rotate) the part so that the intended mirror plane coincides exactly with the origin of the default coordinate system? In that case, I could use the Mirror Evaluation, since the mirror operation would only need to be performed about the X/Y/Z planes. Afterwards, the part could be transformed back to its original position. Is this technically feasible, and is there any functionality that would support this approach? Link to comment https://qualityforum.zeiss.com/topic/26608-mirroring-nominalactualinspection-elements/#findComment-150728 Share on other sites More sharing options...
[Be...] Posted May 18 Share Posted May 18 Hi, the same limitation appears, so the simple answer is 'No'. Again, it's not about the calculation of the needed transformation, it's the expectation that every parametric works in the way the user would expect it and that can't be ensured for arbitrary planes. Therefore we don't support it because you as a customer would have to check each command and their parameters manually after applying the transformation. Regards Link to comment https://qualityforum.zeiss.com/topic/26608-mirroring-nominalactualinspection-elements/#findComment-150734 Share on other sites More sharing options...
