[Da...] Posted May 14 Share Posted May 14 Good morning everyone, Do you know if there's a way to assign different speeds on the same curve? Thanks a lot. Link to comment https://qualityforum.zeiss.com/topic/26618-different-speeds-on-the-same-curve/ Share on other sites More sharing options...
[Ma...] Posted May 14 Share Posted May 14 You have to use segments and don't forget to select all segments and click on "measure in group" - that will avoid approach and retract from scan and it will scan whole curve on one go. Only problem is that all measured points will be in first segment. Without grouping it would act like paths in strategy. Link to comment https://qualityforum.zeiss.com/topic/26618-different-speeds-on-the-same-curve/#findComment-150646 Share on other sites More sharing options...
