[Do...] Posted Thursday at 01:14 PM Share Posted Thursday at 01:14 PM I've never seen this happen, but my measured position is flipped from the nominal. Has anyone seen this before? For context, I am measuring a cylindrical part on a rotary table. The primary Datums A and B are along the Z axis, measured at 3.200" and -3.200" respectively. I construct a 3d line from the circle paths and use that in my base alignment as my spatial and my X and Y. I was going to just take a fresh manual alignment and see if that addresses the issue, but wanted to see if there was anything I should look at first. Link to comment Share on other sites More sharing options...
[Ma...] Posted Thursday at 02:22 PM Share Posted Thursday at 02:22 PM Is you base alignment primary from a cylinder? In that case I would rather scan two circles and make 3d line from them. Link to comment Share on other sites More sharing options...
[Ja...] Posted Thursday at 03:00 PM Share Posted Thursday at 03:00 PM My guess is your strategy circle path has a start height of 3.2, should be zero. Look at the feature and show the nominal circle and the measured points and see if they line up. Link to comment Share on other sites More sharing options...
[Do...] Posted Thursday at 04:10 PM Author Share Posted Thursday at 04:10 PM The alignment was from a 3d line along Z axis and I also had another 3d line constructed from two circles paths along the X axis. I noticed that the planar rotation was affecting the direction as the alignment trihedron was inverted to the part in Z axis. I adjusted the planar and it looks like it works fine now. Thanks all! 2 Link to comment Share on other sites More sharing options...
[No...] Posted 1 hour ago Share Posted 1 hour ago (edited) When making a 3D line from recalled features, the first feature selected determines the origin of the line, the other(s) the direction. So if you select in the wrong order, the axis made from the line may end up flipped. Edited 1 hour ago Link to comment Share on other sites More sharing options...
