[Da...] Posted May 15 Share Posted May 15 Hi All, I am using Calypso 2023 and when I do a calibration program I still use Std.dev formula to check sigma and radius. Is there any easier and quicker method ? Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/ Share on other sites More sharing options...
[Da...] Posted November 9 Author Share Posted November 9 ??? Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/#findComment-158092 Share on other sites More sharing options...
[Ri...] Posted November 9 Share Posted November 9 I am not sure what you are getting at. Are you using a result element to calculate something or visually acknowledging the Sigma and Radius values? FYI Many users use a CMM program that reports the Qualifications of probes and setting tolerances on sigma values. I do this, and I chart the sigmas over time to track the condition of each stylus tip using Excel, simple Bell Curve for normal distribution. Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/#findComment-158102 Share on other sites More sharing options...
[Ri...] Posted November 9 Share Posted November 9 Is there an easier way? Unfortunately not at this moment. Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/#findComment-158110 Share on other sites More sharing options...
[Ch...] Posted November 9 Share Posted November 9 wish zeiss would build something in natively, I mean what year is it ? sheesh 3 Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/#findComment-158116 Share on other sites More sharing options...
[Ma...] Posted November 10 Share Posted November 10 It used to be if your stylus failed qualification the results element would return the value of the previous sigma information. Is it still that way? Link to comment https://qualityforum.zeiss.com/topic/26622-calibration-results/#findComment-158134 Share on other sites More sharing options...
