[Je...] Posted May 15 Share Posted May 15 First is there a setting, utility, plan...something to direct the stylus to approach and retract from the center of a circle when scanning a circle? Because this makes perfect sense... If not, my clearance data is at -.8MM and still off center. So negatives don't work. Thanks. Link to comment https://qualityforum.zeiss.com/topic/26624-8mm-stylus-checking-a-10mm-hole-clearance-clarence/ Share on other sites More sharing options...
[Du...] Posted May 15 Share Posted May 15 set your clearance distance to 0 and retract distance to .1 1 Link to comment https://qualityforum.zeiss.com/topic/26624-8mm-stylus-checking-a-10mm-hole-clearance-clarence/#findComment-150680 Share on other sites More sharing options...
[Ke...] Posted May 15 Share Posted May 15 Retract distance is the distance off the wall for a cylinder, and it is based on ball center. So Retract=( Radius of the hole-Radius of the probe) should put it right down the middle, if the hole is at nominal position (A system cant adjust to a position that it doesn't know yet, so it has to run to the nominal). As Dustin indicated, 0.1 for retract in this case 1 Link to comment https://qualityforum.zeiss.com/topic/26624-8mm-stylus-checking-a-10mm-hole-clearance-clarence/#findComment-150682 Share on other sites More sharing options...
[Ri...] Posted May 15 Share Posted May 15 Please sign in to view this quote. The .1mm would place your stylus in the center from Nominal, not from actual, but it should work out. As for the Clearance Distance, use the default then set the speed to 10. The stylus will move into the hole very slowly. Got to: Resources Feature settings editor Travel Speed (Set to 10). Link to comment https://qualityforum.zeiss.com/topic/26624-8mm-stylus-checking-a-10mm-hole-clearance-clarence/#findComment-150702 Share on other sites More sharing options...
[To...] Posted May 16 Share Posted May 16 Please sign in to view this quote. Retract distance = (hole dia - probe dia) / 2 Clearance distance on a circle or cylinder is parallel to the axis. Link to comment https://qualityforum.zeiss.com/topic/26624-8mm-stylus-checking-a-10mm-hole-clearance-clarence/#findComment-150716 Share on other sites More sharing options...
