[Je...] Posted 3 hours ago Share Posted 3 hours ago First is there a setting, utility, plan...something to direct the stylus to approach and retract from the center of a circle when scanning a circle? Because this makes perfect sense... If not, my clearance data is at -.8MM and still off center. So negatives don't work. Thanks. Link to comment Share on other sites More sharing options...
[Du...] Posted 3 hours ago Share Posted 3 hours ago set your clearance distance to 0 and retract distance to .1 1 Link to comment Share on other sites More sharing options...
[Ke...] Posted 3 hours ago Share Posted 3 hours ago Retract distance is the distance off the wall for a cylinder, and it is based on ball center. So Retract=( Radius of the hole-Radius of the probe) should put it right down the middle, if the hole is at nominal position (A system cant adjust to a position that it doesn't know yet, so it has to run to the nominal). As Dustin indicated, 0.1 for retract in this case 1 Link to comment Share on other sites More sharing options...
