[St...] Posted Friday at 02:40 PM Share Posted Friday at 02:40 PM For some reason the tool rack location for my Master Probe was lost. I have an Accura and it is currently set up with about 16 different probes. I haven't had any issues with any of the racks other that the one for the master probe. The problem is, my master probe is too long to actually touch off on any of the racks. The top level of the rack system has 6 probes stored on it and I need another 2 inches or so of travel in order to get the master probe positioned above the racks so I can touch them off. I didn't set this system up originally, so I have no idea how it was done. I have searched everywhere and cannot find a shorter master probe I could swap out. Is there anyway to set the location of the rack without having to touch off with the Master Probe? Or am I just going to have to bite the bullet and order a shorter probe. Link to comment Share on other sites More sharing options...
[No...] Posted Monday at 07:42 AM Share Posted Monday at 07:42 AM (edited) When we had set up a customized moveable ProMax rack on our ancient MC550 years ago, we also received a shorter master probe. But years later a maintenance guy told me that by using a shorter master probe, the CMM would use the wrong CAA data to correct the measured points. I have no idea if he was right. What I do know is that CAA subdivides the measurement volume into small cubes (?) and and CAA data is determined for each of them. So if the master probe is the reference for all the other probes, what the tech guy said seems to make sense at first glance, but I'm lacking full knowledge about CAA, so I can't say for sure. Edited Monday at 08:08 AM Link to comment Share on other sites More sharing options...
[Ch...] Posted 3 hours ago Share Posted 3 hours ago It has been a while since I have tried to locating the rack with something other then the MasterProbe but I don't believe it's a requirement to use the MasterProbe. As long as you perform the "Define Stylus Length" prior to then locating the holder I believe it will let you use whatever length of stylus you have. It may prompt you asking if the MasterProbe is active but I want to say you can work past that. You may want to make sure to use a stylus diameter similar to that of the MasterProbe however. For example XXT's require ~2.5 radius stylus. Again it has been a little while since I tried this myself so it may be a good idea to back up your CALYPSO config prior to doing so for an easy restore - CALYPSO: How to Backup CALYPSO Config. Link to comment Share on other sites More sharing options...
