[Ma...] Posted May 18 Share Posted May 18 Good morning to all, I need to align a part that has perfect symmetry in Z, but I would like to align the various stages using the figure number on the same side. Unfortunately, the “disc caliper on selection” strategy cannot be applied, because I would like to find the outermost point relative to Z zero, but in this case the maximum point can be either on the Z− side or the Z+ side. Is there any workaround that can be used to achieve this? Thank you very much. Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/ Share on other sites More sharing options...
[Ma...] Posted May 18 Share Posted May 18 I was taught you can export or see maximum model from all stages - but i don't know much more from head and i am not sure if you can do this evaluation across all stages. Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150762 Share on other sites More sharing options...
[Ma...] Posted May 18 Author Share Posted May 18 Excuse me but I didn't understand what do you mean. I have to took the highest point coming from 2 different directions. If the piece was only rotated around the Z axis thsi is not a problem, but in this case I have the piece rotated around the X axis, but I have to take the maximum point coming from Z+ and Z-. I hope I explained myself. Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150764 Share on other sites More sharing options...
[Jo...] Posted May 18 Share Posted May 18 (edited) Maybe if you go by point of maximum curvature on selection? The cavity number should include thhis point with the right selection of surfaces. Probably wont be the max point in z, but at least you can detect the side of the caviity number and with further checks get the max point in z. Edited May 18 Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150768 Share on other sites More sharing options...
[Ma...] Posted May 18 Author Share Posted May 18 Thank you very much! How can I do this? I make a section with the 4 zone, then I make a curve from this section (I found Projected Curve) and finally I tried to make a pojnt of max curvature, but it's not possible to select this curve. Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150770 Share on other sites More sharing options...
[Jo...] Posted May 18 Share Posted May 18 Sorry can`t help you with that. I havent used this function myself yet. Just remembered reading about it somewhere (prob techguide). Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150772 Share on other sites More sharing options...
[Ma...] Posted May 18 Share Posted May 18 Please sign in to view this quote. Once you have a curve, then you can use measuring principle - Curve Curvture. Then you can fill that Curve Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150774 Share on other sites More sharing options...
[Ma...] Posted May 18 Author Share Posted May 18 Yes, thank you Martin and thank you Jochen, with Max Curvature point with curve curvature it works fine. Thank you very much! Link to comment https://qualityforum.zeiss.com/topic/26644-extract-the-maximum-z-point-from-z-and-z-without-script/#findComment-150776 Share on other sites More sharing options...
