[Ma...] Posted May 19 Share Posted May 19 Good morning, Error report attached. Zeiss Pro T2 Advance w/Calypso 2024 7.8.00. Started initial run for a brand new program using a manual alignment. After probing alignment features and clicking through the prompt for switching to CNC Mode is when I get the error. I've tried resetting the software, then the CMM, then shut down everything including the PC and let it sit 25 minutes before restarting, but the problem persisted. I was able to successfully run an existing proven program with no issues, so the error is unique to the program. I appears like I can run program manually, but I have several circles with 40 hits ea. and I'd rather not have to do that. 😄 Any help would be much appreciated, thanks! AER_20260519_102456_069.cef Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/ Share on other sites More sharing options...
[Ma...] Posted May 20 Share Posted May 20 Good Morning Matthew, if you're running the base Version 7.8.00, my first suggestion would be the latest ServicePack, just like Windows, a lot of BUGs get fixed with each Pack. If that doesnt help i would contact your local Software Support and send them the ErrorReport. Best Regards Marcel 1 Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/#findComment-150860 Share on other sites More sharing options...
[Ri...] Posted May 20 Share Posted May 20 When I had a similar error, if not the same, it was due to PCM, an array not calculating because it was setup wrong. 1 Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/#findComment-150880 Share on other sites More sharing options...
[Ma...] Posted May 20 Author Share Posted May 20 I haven't been good at all keeping up with that stuff, so I'll do that. Thanks for the reply! Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/#findComment-150914 Share on other sites More sharing options...
[Ma...] Posted May 20 Author Share Posted May 20 Please sign in to view this quote. I think I did see PCM when I was going over the error report. Can you remember at all what the setup error was? Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/#findComment-150916 Share on other sites More sharing options...
[Ri...] Posted May 21 Share Posted May 21 This was when I had to trouble shoot a similar error. Link to comment https://qualityforum.zeiss.com/topic/26650-unhandled-exception-this-collection-is-empty/#findComment-150932 Share on other sites More sharing options...
