[Ma...] Posted 16 hours ago Share Posted 16 hours ago Good morning, Error report attached. Zeiss Pro T2 Advance w/Calypso 2024 7.8.00. Started initial run for a brand new program using a manual alignment. After probing alignment features and clicking through the prompt for switching to CNC Mode is when I get the error. I've tried resetting the software, then the CMM, then shut down everything including the PC and let it sit 25 minutes before restarting, but the problem persisted. I was able to successfully run an existing proven program with no issues, so the error is unique to the program. I appears like I can run program manually, but I have several circles with 40 hits ea. and I'd rather not have to do that. 😄 Any help would be much appreciated, thanks! AER_20260519_102456_069.cef Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago Good Morning Matthew, if you're running the base Version 7.8.00, my first suggestion would be the latest ServicePack, just like Windows, a lot of BUGs get fixed with each Pack. If that doesnt help i would contact your local Software Support and send them the ErrorReport. Best Regards Marcel Link to comment Share on other sites More sharing options...
