GDT Position, Default diameter name
I really like the new GDT engine and the Position characteristic. I don't need to create separate diameter characteristics before using Position as they are created inside of the GDT Position characteristic. That's good. What I don't like is the default name it gives them: ^Diameter for Cylinder yada yada yada...
Is there a way to change this name? It runs into/cuts off on the results page anyway and just looks ugly on the report.
Thank you
https://qualityforum.zeiss.com/topic/26654-gdt-position-default-diameter-name/
