[Ze...] Posted 7 hours ago Share Posted 7 hours ago I really like the new GDT engine and the Position characteristic. I don't need to create separate diameter characteristics before using Position as they are created inside of the GDT Position characteristic. That's good. What I don't like is the default name it gives them: ^Diameter for Cylinder yada yada yada... Is there a way to change this name? It runs into/cuts off on the results page anyway and just looks ugly on the report. Thank you Link to comment Share on other sites More sharing options...
[Do...] Posted 6 hours ago Share Posted 6 hours ago I believe you can adjust the default names here: C:\Users\Public\Documents\Zeiss\CALYPSO\data\config\NamePatternsDefault Link to comment Share on other sites More sharing options...
[Ri...] Posted 6 hours ago Share Posted 6 hours ago Please sign in to view this username. What version are you on? I believe this was removed in Service Pack 2 of 2025. Link to comment Share on other sites More sharing options...
[Ze...] Posted 5 hours ago Author Share Posted 5 hours ago Hi Richard. I'm using 2024, SP3. I put it in my sig line but it's not showing in my posts for some reason. Link to comment Share on other sites More sharing options...
[Ri...] Posted 4 hours ago Share Posted 4 hours ago I think they disabled that. Either way - that change probably didn't make it to 2024. I do believe someone else posted a workaround. Link to comment Share on other sites More sharing options...
