[Du...] Posted 5 hours ago Share Posted 5 hours ago Any tricks for scanning around features the have a couple 90 degree corners? Link to comment Share on other sites More sharing options...
[Ni...] Posted 4 hours ago Share Posted 4 hours ago Please sign in to view this quote. If it is a result issue mask curve points using the evaluation parameters option at the area where the probe will be scanning around the corner. Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Share Posted 4 hours ago If it's about scanning around sharp edges, than insert a corner point with 45° vector, or ask for model, where will be small radius. And if you need to have as many points close to that corner, then make new segment for that area and scan it with much slower speed. In that case don't forget to select all segments and change them into one group so you can have continuous scan. Link to comment Share on other sites More sharing options...
