Curve Settings & Circle In Contour Measurements
Are there any online trainings that anyone has found that focuses on this area?
I could get good/reasonable results for Center of Ball & Gap measurements, using the initial Curve that I traced, but the Tangents were way off.
I had to measure the feature (Gothic Arch) as a Circle and recall those points into a Curve, in order to get good/reasonable results across the board...
CALYPSO curve eLearning Competence Package for new curve users.
You may be well aware of these resources already but section 4-190 of the C:\Program Files\Zeiss\CALYPSO 8.0\userinfo\manuals\en-US\Calypso_basic_cnc.pdf does go into a bit more detail regarding the Circle in contour best fit construction.
Also C:\Program Files\Zeiss\CALYPSO 8.0\userinfo\manuals\en-US\Calypso_01_curve.pdf can be helpful when looking to understand some of the less common curve functions.
  • Like! 1
