[Be...] Posted May 21 Share Posted May 21 I'm attempting to set up simulations in Planner. I want to create a re-qual program for the different styli that I currently have. When I go to add a rack, the type of holder I need is not in the drop down menu when prompted to "Please select the desired holder". I need an XXT and the only options I have are MT, MT (old), ProMax, and ZCR. Link to comment https://qualityforum.zeiss.com/topic/26678-adding-a-tool-holder-rack-in-planner/ Share on other sites More sharing options...
[Ri...] Posted May 22 Share Posted May 22 You need to setup your machine tab correctly inside of your Planner. Here is a Knowledge Base article on setting this up. https://portal.zeiss.com/knowledge-base?id=520919 Link to comment https://qualityforum.zeiss.com/topic/26678-adding-a-tool-holder-rack-in-planner/#findComment-150996 Share on other sites More sharing options...
