[F....] Posted Wednesday at 04:18 PM Share Posted Wednesday at 04:18 PM (edited) Hello, I am trying to inspect surface point by exporting i, j, k not only x, y, z. I only could see I-tech has x, y, z from drop down list. Does it Dnx, Dny, Dnz? Would someone could help me? Thanks, Edited Wednesday at 04:39 PM Link to comment Share on other sites More sharing options...
[Na...] Posted yesterday at 10:55 AM Share Posted yesterday at 10:55 AM Hi, you can access the values with a user defined check, which can be added to I-Inspect (and saved in an App to have it available across projects. Nanno 1 Link to comment Share on other sites More sharing options...
[F....] Posted yesterday at 05:38 PM Author Share Posted yesterday at 05:38 PM Thanks. However, I tried it on circle center point, there is no actual 3d vector for selecting, only nominal. Is there any way I could find out actual reading? Link to comment Share on other sites More sharing options...
[F....] Posted 23 hours ago Author Share Posted 23 hours ago Thanks. However, I tried it on circle center point, but the nominal reading and actual reading are same. I have to manual type nominal value in the Nominal expression box below actual expression. Link to comment Share on other sites More sharing options...
