[Ni...] Posted May 29 Share Posted May 29 Hello, does anyone know what the weight limit is for workpieces on an RT05-300 rotary table (made in West Germany 😄)? Unfortunately, I don't have the specifications or anything like that. Thanks in advance! Link to comment https://qualityforum.zeiss.com/topic/26744-rotary-table-rt05-weight-limit/ Share on other sites More sharing options...
[Ri...] Posted May 29 Share Posted May 29 (edited) If the naming is like how the new ones are, the -300 represents the Kg workload allowance. Now, what the max mass moment of inertia is a different question. You might have to reach out to someone at Zeiss to get an answer on that though. Looks like Please sign in to view this username. may have had one of these in the past. Edited May 29 Link to comment https://qualityforum.zeiss.com/topic/26744-rotary-table-rt05-weight-limit/#findComment-151348 Share on other sites More sharing options...
[Ch...] Posted May 29 Share Posted May 29 I did used to have one. And really liked it actually. I don't have the documentation for it anymore, but I can tell from experience it holds more than you would expect. It moves pretty slow, I would think that means the MMI would have less of an impact compared to the RTAB. Its also build like a tank inside of it. Its basically 1 solid gear. Structurally, I can't imagine the weight of the part having much of an impact so long as the motor can turn it. Link to comment https://qualityforum.zeiss.com/topic/26744-rotary-table-rt05-weight-limit/#findComment-151352 Share on other sites More sharing options...
[Ni...] Posted June 1 Author Share Posted June 1 Thanks for your feedback, everyone. I received this table from Zeiss Support. Our workpiece weighs “only” 35–40 kg, so it shouldn't be a problem... I think. Link to comment https://qualityforum.zeiss.com/topic/26744-rotary-table-rt05-weight-limit/#findComment-151406 Share on other sites More sharing options...
