plugin_preCharacteristic_pcm.txt
  • [Jo...] changed the title to plugin_preCharacteristic_pcm.txt
figured out what the problem was... i needed to put my copy file code in the pre_start pcm file instead of start.... but this leads to another problem .....
What i am trying to do is set a characteristic attribute to every characteristic in the program.  the same attribute will be the same for everything except the 1st characteristic..
i have a counter variable that i am using so the code looks like
setCFAttribute("u_my-var","null")
if counter == 1 then
setCFAttribute("u_my-var",my_var2)
counter=2
endif
this works perfectly except if the first characteristic is a  loop.. ie  (1,,8,1)mydim....  however if i manually put it into the pre-settings with just setCFAttribute("u_my-var",my_var2), it puts it in...   what am I missing?
