[Br...] Posted June 2 Share Posted June 2 Hi everyone I would like to generate a Surface Comparison of an area on a CAD part against different Actual parts, without having the operator influence every time (i.e., having to manually select it in red before generating the Surface Comparison). Therefore, I am looking for a solution that allows me to mark (or segment) an area on a CAD part, kind of making it a new object (or area) that would be ´pre defined´ every time I upload an Actual Part. Would anyone have tried it or know about any possibility to make it possible? Best regards Bruna Link to comment https://qualityforum.zeiss.com/topic/26756-possibility-to-compare-a-same-area-on-a-cad-part-against-different-actual-parts/ Share on other sites More sharing options...
[Ma...] Posted June 2 Share Posted June 2 You can set it up with stages and make a flipbook ( or separate pdfs ) or you can do it manually by replacing actual data. Then it's the same - just recalculate project to se changes. Of course, you must first define your checks (deviations, dimensions, ...) Link to comment https://qualityforum.zeiss.com/topic/26756-possibility-to-compare-a-same-area-on-a-cad-part-against-different-actual-parts/#findComment-151430 Share on other sites More sharing options...
