Help me understand how/when to apply an evaluation filter (Gauss) to a 2D Curve
Posted (edited)
Hello,
I am hoping to get some input on how best to use, or when to use a gaussian low pass filter on a 2D Curve. For some context, my organization does a lot of profile controls - for example all unspecified surfaces are typically controlled by a profile of .020 to DATUM A/B/C. The vast majority of our profile measurements are captured through 2D or 3D curves that are a combination of linear surfaces and radii. (Screenshot of feature below is an example of what our strategy may look like.) Up to this point we have not applied filter/outlier elimination to the features themselves, and typically just insert the raw data into a Line or Surface profile characteristic.
After reading up a bit on the Gauss low-pass filter setting that can be turned on/off on our curves I believe it may be appropriate for us to start utilizing that setting at times. So here is my understanding of the usage.
-The filter is used to smooth a profile to compensate for surface finish/roughness of material
-A minimum of 7 points is required (question here from me is this per wavelength based on the Lc setting, or for the entire curve length?)
-The wavelength cutoff setting (Lc) should be selected based on the expected roughness of the surface? (is the surface roughness conversion chart I have in a image below a good resource for selecting 'Cut-off length / Lc?'
-What is the 'connect segments' setting is under the filter
-In the third image below, is it appropriate to use this filter, on this specific curve when measuring it as a profile, and what should the specific settings be? The maximum allowed surface roughness is 125 (microinches) but will likely fall between 30-62 (microinches.)
-Any suggestions on how or when to appropriately apply the Gauss, low-pass filter to a 2D curve feature that is measuring surface profile would be greatly appreciated..
Edited
My company has been using 2d curves for ages. They strictly use spline, and it seems to work for them. I have not deviated from this to avoid impacting production.
I have questioned the Lc value, though, and am interested in others' thoughts.
That is not always the case and I suggest to look at the post from Klaus-Dieter here:
https://qualityforum.zeiss.com/topic/24879-rules-of-thumb-for-2d-curve-evaluations/#comment-141085
Especially the files he sent.
Edited
More info
  • Like! 1
