[Ri...] Posted Thursday at 04:34 PM Share Posted Thursday at 04:34 PM I have this one stubborn program, every time I open it, I am warned that a probe is not available. Combo86R-2 It is not used in the program; it has never been used in the program. Any ideas on how I may be able to find a rogue entry in some file? Link to comment Share on other sites More sharing options...
[Du...] Posted Thursday at 04:46 PM Share Posted Thursday at 04:46 PM Have you checked the stylus system dropdown in the measurement plan editor features? Link to comment Share on other sites More sharing options...
[Th...] Posted Thursday at 04:48 PM Share Posted Thursday at 04:48 PM I know that probe names show up in the inspection file if I search for them. Link to comment Share on other sites More sharing options...
[Ke...] Posted Thursday at 04:53 PM Share Posted Thursday at 04:53 PM Have you checked which stylus is used under "Meaasurement Plan Editor Features"? Or are there any known position points that might have been misassigned? Link to comment Share on other sites More sharing options...
[Ri...] Posted Thursday at 05:16 PM Author Share Posted Thursday at 05:16 PM (edited) I have checked the obvious, Measurement Plan Editor, no entries shown. I did find entries in "inspec" and "inspection" files. Editing those entries caused some weird problems (Altered the entries to be Combo86R). 😂 inspec file: Please sign in to view this quote. inspection file: Please sign in to view this quote. I could not find an "#identifier" within plus or minus 30 lines of the "Combo86R-2" line. Edited Thursday at 05:16 PM Link to comment Share on other sites More sharing options...
[Do...] Posted Thursday at 05:20 PM Share Posted Thursday at 05:20 PM CMM positions and start/end park positions are sneaky places where probes can be assigned, but are not visible via the Plan Editor. 3 Link to comment Share on other sites More sharing options...
[Ri...] Posted Friday at 11:22 AM Author Share Posted Friday at 11:22 AM Screen shot of used probes in the program, not showing this Combo86R-2 which is an actual probe. Link to comment Share on other sites More sharing options...
[Ch...] Posted Friday at 01:33 PM Share Posted Friday at 01:33 PM Please sign in to view this quote. could also be hiding in an 'intermediate point' in a strategy , perhaps you wont see that in the plan editor. I've had this happen occasionally while opening and reviewing strategies etc. Link to comment Share on other sites More sharing options...
[Ke...] Posted Friday at 01:41 PM Share Posted Friday at 01:41 PM You could try assigning a different stylus system and then changing it back, to try and overwrite any hidden problems 🤷♂️ 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted Friday at 03:03 PM Share Posted Friday at 03:03 PM That was my next suggestion as well, this might cover any intermediate points that are mis-assigned, if you just re-assign all probes in the test editor... Link to comment Share on other sites More sharing options...
[Br...] Posted Friday at 06:36 PM Share Posted Friday at 06:36 PM Another place to check is your CMM END PARK POSTION there might be a Stylus/system in there that no longer exists. 2 Link to comment Share on other sites More sharing options...
[Ri...] Posted yesterday at 10:43 AM Author Share Posted yesterday at 10:43 AM I am not or have not used park positions in this program. 1 Link to comment Share on other sites More sharing options...
[ni...] Posted yesterday at 11:29 AM Share Posted yesterday at 11:29 AM with a copy of your program, defined new elements for the aligment and erase all the other element and try to launch the program, if the problem is still there it's not cause of an element, if the problem disappear, do the same thing again and erease just half of the other element (and a quarter and a 1/8....) to find the problem element. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted yesterday at 03:28 PM Share Posted yesterday at 03:28 PM Sounds like the stowaway onboard your program is doing a good job at hiding. You've checked the obvious places. Any stones left unturned as pcm in comments or stylus qualifications or shady, dimly lit taverns? 2 Link to comment Share on other sites More sharing options...
[Ri...] Posted 7 hours ago Author Share Posted 7 hours ago Please sign in to view this quote. I found the probe name in inspset and inspection files, removing those entries caused unexpected results that made the program crash. Link to comment Share on other sites More sharing options...
[Ma...] Posted 7 hours ago Share Posted 7 hours ago Hello Please sign in to view this username. , if you want (and if its allowed to) you can send me the program via PM and i can take i look. Best Regards Marcel Link to comment Share on other sites More sharing options...
[Jo...] Posted 5 hours ago Share Posted 5 hours ago I have run into this as well and am curious about the fix in your situation. One suggestion that I can provide is that sometimes groups can hold the stylus name in them, even when not all the sub-features are set to the stylus system. You should have stumbled upon this in the MMPE, so I don't believe this helps you. You could try removing any grouped features and regrouping them maybe. Link to comment Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago Please sign in to view this username. I've found that in "inspection" file there is twice section of "OMTecSafety" in which is one probe system and i secondary there is another probe system. All other features have only one definiton of that "OMTecSafety" Not sure how that happened, but Richard has my findings even which feature it is, so i hope it will be founded. 1 Link to comment Share on other sites More sharing options...
