[Br...] Posted June 4 Share Posted June 4 In "Define and Activate Limit Values" I have "Maximum permissible time...." set for 2 days. In "Stylus check during CNC start" I have "Cancel CNC start" selected. In Calypso, we get a message when the probes haven't been calibrated within that time frame. In AutoRun, it doesn't give us a message. If I close AutoRun and start Calypso it immediately shows the message when opening a program. Do I need to set something up in AutoRun for it to work? Link to comment https://qualityforum.zeiss.com/topic/26776-stylus-check-during-cnc-start-not-working-in-autorun/ Share on other sites More sharing options...
[Ma...] Posted June 4 Share Posted June 4 Did you have "Cancel CNC start" selected and program saved before adding the measurement plan to Autorun? If not, and you selected this after you had already added the measurement plan to Autorun you may need to add it again. Link to comment https://qualityforum.zeiss.com/topic/26776-stylus-check-during-cnc-start-not-working-in-autorun/#findComment-151496 Share on other sites More sharing options...
[Br...] Posted June 4 Author Share Posted June 4 Pretty sure that I did but I'll try it again. Thank you. Link to comment https://qualityforum.zeiss.com/topic/26776-stylus-check-during-cnc-start-not-working-in-autorun/#findComment-151498 Share on other sites More sharing options...
