Hello,
I'll have to pass through a Ø50±0.1mm to mesure a inner diameter of Ø68E7 (65mm long) , for that I found on the web a  Stemless Disks of Ø50mm, with a M5 threaded center, how can I assemble it, is it just with a standard screw on a standard extention ? and how I will calibrate it ? (I know how to calibrate a standard disk ) inquire if the thick of the screw will matter ?
do you think about an other method / material  to mesure this Ø68 ?
https://qualityforum.zeiss.com/topic/26780-disk-stylus-%C3%B840mm/
this answer of the dealer is that this disk with M5 is to assemble with an other stylus, for just a disk a have to take a bolt hold disk and a special screw with it.
And for the calibration I think a standard calibration and take the first Z point on the edge of the disk instead of center.
  • Like! 1
