Miniplan to Determine Piweb Reports
I have a program that has multiple mini plans. For one specific miniplan, I would like to include a process protocol in addition to the standard protocol. For all other mini plans, just the standard protocol.
Is this possible?
  • 2 weeks later...
This should be possible with PCM in your program presetting.
I have not tested this, but here is some rough code that should help you get started. You can add more if/then legs to be more specific.
MiniPlan=getRunID()
If MiniPlan= *your miniplan name*
setProtocolOutput(*appropriate Syntax*)
else set ProtocolOutput(*appropriate Syntax*)
endif
