[Ma...] Posted June 5 Share Posted June 5 I have scanned 3 circle paths on 3 planes and one is offset so I made an offset plane but when I try to get flatness off of them it come out as perfect even thought the individual planes have some form deviation. Any thoughts? Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/ Share on other sites More sharing options...
[Ch...] Posted June 5 Share Posted June 5 offset plane is theoretically perfect I believe. Just create regular plane from scans and check flatness before offsetting ? Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/#findComment-151540 Share on other sites More sharing options...
[Ma...] Posted June 8 Author Share Posted June 8 If I recall the feature points into plane the result is like 1.7 which I know isn't right and its called out as a continuous zone so they have to be evaluated as one plane. Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/#findComment-151554 Share on other sites More sharing options...
[Ke...] Posted June 8 Share Posted June 8 If its a Flatness callout, but the planes are offset (are that offset by 1mm?), perhaps, you need to evaluate Profile of a Freeform Surface (with no Datums)? ...do you have Freeform on your CMM? Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/#findComment-151558 Share on other sites More sharing options...
[Ma...] Posted June 8 Author Share Posted June 8 Unfortunately not on the offline seat, our CMM is down for calibration this morning, they are offset by 11.3 mm and the other two are on the same level, I would think there would be an easier way to do it. Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/#findComment-151572 Share on other sites More sharing options...
[Ke...] Posted June 8 Share Posted June 8 (edited) "How to Control Offset Planes To design and inspect two offset, nominally parallel planes so they act as a single functional feature: Use Basic Dimensions: Apply exact, untoleranced (basic) dimensions between the surfaces. Apply Profile Tolerance: Attach a Profile of a Surface symbol (e.g., \bigcirc \mkern-5mu \vert{} \mkern-5mu \bigcirc with a value of 0.05 mm) to the Feature Control Frame (FCF) for both surfaces. This ensures both surfaces are held coplanar within the same tolerance zone GD&T Tips - For Coplanarity Use Profile - Tec-Ease. [1] Add Datums as Needed: Depending on how the planes mate in an assembly, you can orient the profile zone relative to an established datum system, or leave it datainless for free-floating coplanarity" "Common Mistakes to Avoid Using Flatness on Both: If you try to call out individual Flatness on two separate offset surfaces, each surface is evaluated indepenantly. The GD&T specification does not enforce that the two planes be co-planar, parallel, or at the correct basic offset to one another Flatness OR Profile ON Flat Surface. " Edited June 8 Link to comment https://qualityforum.zeiss.com/topic/26790-flatness-on-offset-planes/#findComment-151582 Share on other sites More sharing options...
