[Ri...] Posted June 8 Share Posted June 8 I am working on an older program where the original author used very large Clearance and Retract values as a Default for all programs. I can't recall how to change the entire program to new Default values for when new features are created, they use the new Default values. Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/ Share on other sites More sharing options...
[ni...] Posted June 8 Share Posted June 8 (edited) Hi, in french (and on calyspo 5 :) ) it's : extra / "espace de travail" / mesure Edited June 8 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151552 Share on other sites More sharing options...
[Ri...] Posted June 8 Author Share Posted June 8 I have changed those settings; it has no effect on new features. Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151568 Share on other sites More sharing options...
[No...] Posted June 8 Share Posted June 8 To change this for an existing measurement plan, go to the measurement plan features editor, select the section with clearance and retract distances and change the values for the whole plan instead of just selected elements. 4 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151570 Share on other sites More sharing options...
[Ri...] Posted June 8 Author Share Posted June 8 Thanks Norbert, that seems to have worked. 1 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151576 Share on other sites More sharing options...
[Za...] Posted June 11 Share Posted June 11 for anyone else visiting this article at a later date, here's a KBA on the topic. https://portal.zeiss.com/knowledge-base?id=3139416 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151693 Share on other sites More sharing options...
[Pa...] Posted June 14 Share Posted June 14 Please sign in to view this quote. When I took Calypso Basic and Advanced in like 2014, Please sign in to view this username. was the instructor. He did not refer to this button as "Measurement Plan Editor Features", he called it "Tom's Favorite Button". I still use the latter to this day 🙂 2 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151773 Share on other sites More sharing options...
[Za...] Posted June 15 Share Posted June 15 Please sign in to view this quote. lol as an instructor myself i refer to it as "the most powerful window in all of CALYPSO." it turns you from a good programmer into a good AND FAST programmer. 2 Link to comment https://qualityforum.zeiss.com/topic/26792-change-clearance-and-retract-distance-to-new-default-values/#findComment-151809 Share on other sites More sharing options...
