Translation and rotation help in FF
I have a round part with a plane close to the top. Datum B is the plane. Datum A is the OD. Base alignment is the plane as Spatial and Z Origin, OD is X and Y origin, and there is a small slot in the top plane the is perpendicular to the plan, but rotated 15 degrees. This slot is my rotation in the base alignment. On top of the -B- plane is a scrollwork like feature with a profile to ABC. There is also a profile for the scrollwork. This scroll work walls are basically perpendicular to the plane -B-. How do I set up the fitting options for the scroll work freeform in order for the profile to just A and B reads correctly. I think I want to allow rotation and X and Y and that's it (Looking for advice to understand)? When you check the box is that allowing rotation or stopping it?
https://qualityforum.zeiss.com/topic/26803-translation-and-rotation-help-in-ff/
What is checked, then it's used.
If there is a profile callout with datums, then you have to look what is free. If you have only A and B in callout's datum, then you allow only rotation - nothing more.
If you have a newer Calypso, then use GD&T and fill only used datums - rotation will be automatically added.
I made two freeform surfaces that use the same feature points recalled into the freeform. One I didn't change anything. The other I allowed rotation around z. I get identical numbers from the profile to abc and profile to a and b only. I'm not sure where I went wrong. My freeform knowledge needs to get better.
First of all - if you are talking about bestfitting in feature evaluation, then this is only applied if you make an alignment from this bestfit and then use it instead of datums.
You should get different results between ABC and AB only - if those datums are able to allow rotation and/or movement.
Because of no drawing was posted, then you can have different situation with datum A - it can be a cylinder ( datum marked anywhere on feature of line of dimension ) or it can be a circle ( datum marked exactly next to dimension number ).
In 2nd situation it should work automatically.
In 1st situation i would make datum B an intersection of a cylinder A and a plane B - to allow rotation.
