Hi Pierre,
my brain is making funny stuff out of your picture perpective wise regarding the orientation of plane 1. Is plane 1 perpendicular to both cylinder axis?
If this is the case you could measure two cylinder for example like Martin has described and build a symmetrie axis. Depending on the part (form deviation) and function it could be better building this with just two circles start and end of the cylinders.
Plane 1 would then be defined by the end surface of the two cylinder.
Edited
https://qualityforum.zeiss.com/topic/26807-pierre/#findComment-151717
