[Ch...] Posted June 12 Share Posted June 12 Hello. I am attempting to measure this dimension here. The depth of a screw hole not including the taper at the bottom. I am attempting to do this by extracting the tapered section as a cone, and the hole as a cylinder. Then I create an intersection plane between the two, and measure that to an intersection plane of the cylinder and front surface. When I attempt to make the intersection between a cone and a cylinder, it places the result at the pointed tip of the cone, and not the intersection plane between the two. What is causing this? Thank you for any help Link to comment https://qualityforum.zeiss.com/topic/26815-cone-and-cylinder-intersection/ Share on other sites More sharing options...
[Da...] Posted June 12 Share Posted June 12 Use Construction > Cone calculations Link to comment https://qualityforum.zeiss.com/topic/26815-cone-and-cylinder-intersection/#findComment-151747 Share on other sites More sharing options...
[Pe...] Posted June 12 Share Posted June 12 A blind hole depth isnt a dimension I would typically ever put on a cmm. But you could try this: https://cmm-quarterly.squarespace.com/articles/calypso-blind-hole-depth 1 Link to comment https://qualityforum.zeiss.com/topic/26815-cone-and-cylinder-intersection/#findComment-151749 Share on other sites More sharing options...
[Je...] Posted June 13 Share Posted June 13 did you check the shell-button? 1 Link to comment https://qualityforum.zeiss.com/topic/26815-cone-and-cylinder-intersection/#findComment-151751 Share on other sites More sharing options...
