Importing a Photogrammetry refxml
Hi,
i was able to do that like this.
  1. have a CAD model of that frame ( to be able to do alignment )
  2. scan that frame with ref. points on that frame
  3. do an alignment in which you will export data
  4. export all ref. points ( it's a xml so you can easily remove unwanted ref. points )
  5. now you can import that fram in setings.
All you have to do is correctly set temperature and material in export and import.
  • Like! 1
Hi Dustin,
I think easiest way would be this function:
https://techguide.zeiss.com/en/zeiss-inspect-2026/article/cmd_manage_alignment_replace_initial_alignment_with_best_fit_by_reference_points.html
this might also help:
ZEISS Quality Tech Guidehttps://techguide.zeiss.com/en/zeiss-inspect-2026/article/cmd_cad_transform_reference_points_to_fixture.html
The reference points are transformed together with the mesh, so depending on the alignment they might be not on the fixture when the part mesh is aligned to the CAD.
Nanno
Seems the 2017 version i am running does not have that edit initial alignment option. I was able to delete all the previous alignments and access the LBF by reference points. I got some questions
1.  How does GOM understand how to use the imported refXML for polygonization? My understanding of photogrammetry is that this will increase accuracy of transformations
2. The REFXML doesnt come into effect until the scan gets done and it then aligns the imported point cloud to the newly scanned fixture, how does this improve scan parameters? once the ref points are aligned, do the imported nominals readjust the newly scanned ref points?
3. only way to confirm that photogrammetry is working is to do a type 2 or type 1?
Just trying to wrap my head around the whole process.
Thank you
Well i am using that for removal of fixture from mesh.
In program i am importing cad model and assigning it as a fixture. Then i am selecting used fixture in Aquisition menu.
Now fixture model is exactly where ref points is telling ( according to refxml definition )
I believe after scan and background removal you normally polygonize. Then you go to selection by mesh - select fixture and define far away from model you will select on mesh. Now press Ctrl+Delete to remove selected mesh.
Are you using a manual system (ATOS not moved by robot) or a scanbox? The workflow is described here for a scanbox:
After the import of the reference points as 'pre-measured reference points', make sure to set the measurement dependency of your ATOS measurement series to the imported points.
There was a discussion some time ago about photogrammetry and its benefits:
