Importing a Photogrammetry refxml
I have an ATOS Template setup, recently we had our frame have photogrammetry. Is there somewhere i can read over the steps to import that ref frame points and align it to the current location of the scan?
Hi,
i was able to do that like this.
  1. have a CAD model of that frame ( to be able to do alignment )
  2. scan that frame with ref. points on that frame
  3. do an alignment in which you will export data
  4. export all ref. points ( it's a xml so you can easily remove unwanted ref. points )
  5. now you can import that fram in setings.
All you have to do is correctly set temperature and material in export and import.
