[Pa...] Posted June 17 Share Posted June 17 Hi All, I am a beginner to zeiss inspect software. I want to measure dimension of the hexagon on my part. I have access to CAD file but it doesn't contain PMI tags. I need to manually construct the features on CAD first before inspecting on actual part. How can I do it on zeiss inspect optical 3D 2026? Link to comment https://qualityforum.zeiss.com/topic/26837-measuring-hexagon/ Share on other sites More sharing options...
[Ma...] Posted June 17 Share Posted June 17 I don't know how to correctly measure this, but you can make sections to get hexagon and evaluate that. Or measure distance of two opposing planes via symmetry plane and GD&T 1 Link to comment https://qualityforum.zeiss.com/topic/26837-measuring-hexagon/#findComment-151913 Share on other sites More sharing options...
[Jo...] Posted June 18 Share Posted June 18 (edited) Never seen "HEX" in a drawing or standard as a defined term. There should be the appropriate standards mentioned on the drawing, that tell you how to interpret this. Otherwise what martin said. Edited June 18 Link to comment https://qualityforum.zeiss.com/topic/26837-measuring-hexagon/#findComment-151939 Share on other sites More sharing options...
[Di...] Posted June 29 Share Posted June 29 That's a classical linear size with some extra information that is not very relevant for the process itself. So the way to solve this would be GD&T Quick Creation -> Independency principle (as we have here an ISO based drawing) -> Select 2 planes -> Right click -> Enter given tolerances -> Done. Repeat until all three possible linear sizes are covered. Hope that helps Best regards Dinko Link to comment https://qualityforum.zeiss.com/topic/26837-measuring-hexagon/#findComment-152253 Share on other sites More sharing options...
