[To...] Posted June 17 Share Posted June 17 I have my thoughts on what is going on with this circle, but I'd like to hear what you all think. Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/ Share on other sites More sharing options...
[Ch...] Posted June 17 Share Posted June 17 i've seen this once or twice before, I think I recall it was a hole and something was causing probe to shank, or it was really out of round ,etc. 3 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151895 Share on other sites More sharing options...
[Ja...] Posted June 17 Share Posted June 17 I suspect similar to Chris - probe shanking out, an out of round hole or a burr, or a combination of all three. 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151897 Share on other sites More sharing options...
[Ke...] Posted June 17 Share Posted June 17 (edited) I see this a lot, when I am measuring a small internal diameter with a "not small enough" stylus. e.g.: inspecting a 4mm dia hole with a 3mm stylus. After I use a 2mm or 1.5mm stylus, the geometery looks good; but the values are no different than the larger stylus Edited June 17 2 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151899 Share on other sites More sharing options...
[To...] Posted June 17 Author Share Posted June 17 The thing that puzzles me is the low form value. Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151901 Share on other sites More sharing options...
[Du...] Posted June 17 Share Posted June 17 Do you have Magnification for the feature on? Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151903 Share on other sites More sharing options...
[Ch...] Posted June 17 Share Posted June 17 Please sign in to view this username. I'm with you, what's up with the good form value? Looks heavily filtered. I'd look at the unfiltered data and check difference been min circumscribed and max inscribed. 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151905 Share on other sites More sharing options...
[To...] Posted June 17 Author Share Posted June 17 (edited) No mag. No filters or outliers. Not sure why scanning 750 degrees. LSQ. Haven’t checked mask settings. Edited June 17 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151907 Share on other sites More sharing options...
[Ch...] Posted June 17 Share Posted June 17 Please sign in to view this username. something is masking out points. its set to 1048 points but only 462 are used for the evaluation. 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151909 Share on other sites More sharing options...
[Ke...] Posted June 17 Share Posted June 17 Try taking discrete points... maybe a dozen or so? Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151911 Share on other sites More sharing options...
[Pe...] Posted June 17 Share Posted June 17 I've seen calypso make some pretty funny shapes when a hole is so far from where it should be. Looking at your X and Z. 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151919 Share on other sites More sharing options...
[Mi...] Posted June 17 Share Posted June 17 (edited) Is there a loose/damaged component? The low form error is confusing, though. Does it have something to do with the fact that it's labeled a cylinder but has the circle symbol in the feature window? Seems like there was some tinkering with that feature at some point. I agree with the previous replies about shanking and burrs but I'd think the form error would be higher, even with filtering. I've seen something similar to that caused by a cracked (off brand) carbon fiber extension. The crack was causing the extension to flex more one way than the other and the result was similar to what you have pictured. Edited June 17 More information Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151927 Share on other sites More sharing options...
[Tr...] Posted June 17 Share Posted June 17 Had this happen when the hole is small, relative to probe, and out of expected position. 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151931 Share on other sites More sharing options...
[To...] Posted June 18 Author Share Posted June 18 Please sign in to view this quote. Please sign in to view this username. I remember many years ago that masking was tied solely to the first .25 seconds of the beginning of a scan, and it still is when scanning less than 360°. So, when you scanned 380° on a circle, the masked points might only be a portion of the 20° over-scan relative to the scanning speed. Then, Calypso changed to masking whatever the over-scan amount was. My assumption is that even though they are scanning 750°, the resulting circle is only using the data from the last 360° of the scan. Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151951 Share on other sites More sharing options...
[To...] Posted June 18 Author Share Posted June 18 (edited) For a little more detail, the basic shape is a cube with many same-sized holes machined parallel to axes created from opposite corners of the cube. All of these holes exhibit the same odd shaped data set. With the exception of the good form, I believe the stylus is shanking. These results lead me to believe there is either an issue during the machining or the base alignment. The measurement plan is from the customer and the results from a part they machined on their machine. I just need to be sure before I tell the customer. Edited June 18 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151955 Share on other sites More sharing options...
[Ri...] Posted June 18 Share Posted June 18 Are you using an L shaped probe? Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-151973 Share on other sites More sharing options...
[To...] Posted June 23 Author Share Posted June 23 Please sign in to view this quote. no Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-152059 Share on other sites More sharing options...
Popular Post [To...] Posted June 23 Author Popular Post Share Posted June 23 It has been determined the part is being machined off axis and when it is mounted on cmm, the probe is shanking. 4 1 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-152061 Share on other sites More sharing options...
[Ja...] Posted June 24 Share Posted June 24 Please sign in to view this quote. Pretty sure this is what the issue is. Calypso wants to attach the measured points to the nominal geometry but since the center of actual hole is closer to one edge you get this kidney bean looking display. If you move the nominal geometry to match the measured you should see the points display correctly. You can see it in simulation as well, make a hole, simulate the data then move the nominal geometry around and the watch the display bend the points around. 3 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-152133 Share on other sites More sharing options...
[Sh...] Posted July 6 Share Posted July 6 We see this all the time and it's typically with programs that we do not have official Base Alignments and are using a common Load Alignment. In my opinion is it solely a CAD issue because Calypso is expecting the physical results (points) to be in the same area as the CAD model after a Base Alignment. I figured it was the Base Alignment/Load Alignment because when I would see this same scan points similar to what you've shown, I'd do a quick program with a Base Alignment and not see that issue with the CAD. 2 Link to comment https://qualityforum.zeiss.com/topic/26841-your-opinion-please/#findComment-152461 Share on other sites More sharing options...
