[To...] Posted 2 hours ago Share Posted 2 hours ago I have my thoughts on what is going on with this circle, but I'd like to hear what you all think. Link to comment Share on other sites More sharing options...
[Ch...] Posted 1 hour ago Share Posted 1 hour ago i've seen this once or twice before, I think I recall it was a hole and something was causing probe to shank, or it was really out of round ,etc. 2 Link to comment Share on other sites More sharing options...
[Ja...] Posted 1 hour ago Share Posted 1 hour ago I suspect similar to Chris - probe shanking out, an out of round hole or a burr, or a combination of all three. 1 Link to comment Share on other sites More sharing options...
[Ke...] Posted 1 hour ago Share Posted 1 hour ago (edited) I see this a lot, when I am measuring a small internal diameter with a "not small enough" stylus. e.g.: inspecting a 4mm dia hole with a 3mm stylus. After I use a 2mm or 1.5mm stylus, the geometery looks good; but the values are no different than the larger stylus Edited 1 hour ago 1 Link to comment Share on other sites More sharing options...
[To...] Posted 1 hour ago Author Share Posted 1 hour ago The thing that puzzles me is the low form value. Link to comment Share on other sites More sharing options...
[Du...] Posted 1 hour ago Share Posted 1 hour ago Do you have Magnification for the feature on? Link to comment Share on other sites More sharing options...
[Ch...] Posted 59 minutes ago Share Posted 59 minutes ago Please sign in to view this username. I'm with you, what's up with the good form value? Looks heavily filtered. I'd look at the unfiltered data and check difference been min circumscribed and max inscribed. Link to comment Share on other sites More sharing options...
[To...] Posted 57 minutes ago Author Share Posted 57 minutes ago (edited) No mag. No filters or outliers. Not sure why scanning 750 degrees. LSQ. Haven’t checked mask settings. Edited 57 minutes ago Link to comment Share on other sites More sharing options...
[Ch...] Posted 21 minutes ago Share Posted 21 minutes ago Please sign in to view this username. something is masking out points. its set to 1048 points but only 462 are used for the evaluation. Link to comment Share on other sites More sharing options...
[Ke...] Posted 10 minutes ago Share Posted 10 minutes ago Try taking discrete points... maybe a dozen or so? Link to comment Share on other sites More sharing options...
