[Fl...] Posted June 24 Share Posted June 24 Hi, Can you please help me with an idea of how to measure a profile on a radius form certain points? So i have 11 points that are already defined on the radius and i want to construct a curve from this points and measure line profile. It is ok to use construct curve or smoothed spline curve? Thanks Ciprian Link to comment Share on other sites More sharing options...
[Ma...] Posted June 24 Share Posted June 24 What you want to achieve? Measured deviation on those points or whole curve? Link to comment Share on other sites More sharing options...
[Fl...] Posted June 24 Author Share Posted June 24 I want to measure the whole curve , line profile for the whole curve made from these 11 points Link to comment Share on other sites More sharing options...
[Jo...] Posted June 24 Share Posted June 24 Hi Florin, i am not sure if it even makes sense to create a curve with so few points and evaluate it, because most of the what you are going to evaluate will be "not really exisiting". You could instead evaluate the position of each point and the result would be the worst deviation. Link to comment Share on other sites More sharing options...
[Ma...] Posted June 24 Share Posted June 24 I think you can easily skip those points and create section, which can be evaluated as profile directly 1 Link to comment Share on other sites More sharing options...
[Fl...] Posted June 24 Author Share Posted June 24 I have a specification and i need to use those points as i have to compare the results with same method, same points on CMM. I measured also position for each point and i have the same result with line profile Link to comment Share on other sites More sharing options...
[Jo...] Posted June 24 Share Posted June 24 (edited) Thought so, remnants of an old measurement with a switching sensor on a cmm 🙂 If the results for postions and the curve you build are the same, then use it the way you have it set up and do a measurement comparision with 10 parts (Evaluating the max diff between both system) Best would be to track both the curve results and the position rssults just in case. Edited June 24 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 24 Share Posted June 24 I still don't understand your measurement. If it's defined radius then don't bother with a curve. If you need to set datum for that by those 10 points, then do that ( example: by besfitting those points ). Link to comment Share on other sites More sharing options...
