[Ri...] Posted June 24 Share Posted June 24 (edited) I have a print where non-toleranced features fall under Note 7. Note 7 is a profile of Unequal Distribution .040/.010 Then there is Note 17, which allows for a surface condition. See attached image. How do I implement Note 17 in the Profile requirement? Edit:Â I am unable to find a single instance where Flag Note 17 is applied to a feature. All Notes are "Unless Otherwise Specified". Now I wonder if Note 17 is a general note and not applicable on this particular blueprint. Edited June 24 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted June 24 Share Posted June 24 Never had something like this before.  I would measure the depth of surface texture (value below 0,015) and hope that it is quite uniform and put it on the tolerance (additive). Now do you put it on the tolerance out or in the material or 50/50? This is pretty much impossible by the info given alone. One could decide depending on how the texture is achieved. Is something added to achieve the texture or is something removed to achieve the texture?  Thinking about the wording ... I would read "in addition" as additive material wise (non native speaker). Link to comment Share on other sites More sharing options...
[Ri...] Posted June 24 Author Share Posted June 24 Please sign in to view this quote. Note 17 displays the .015 allowance as a stock added condition. Link to comment Share on other sites More sharing options...
[Jo...] Posted June 24 Share Posted June 24 "Note 17 displays the .015 allowance as a stock added condition." 42 Â Â Link to comment Share on other sites More sharing options...
[Ni...] Posted June 24 Share Posted June 24 If the surface texture has not been applied to the part yet, then I would ignore the note entirely. I'm assuming this note is to control surfaces that get powder coating / paint, so it is an N/A situation if the inspection is being performed prior to coatings. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted June 24 Author Share Posted June 24 (edited) Please sign in to view this quote. Maybe I should have included this note. 🫤 I think Note 9 applies to Note 17.  Edited June 24 Link to comment Share on other sites More sharing options...
[Ri...] Posted June 24 Author Share Posted June 24 (edited) Snippet from the print, initially I read this as two separate instructions. Now I am leaning on the Note 9 is a construct of how Flag Note 17 is applied where applicable while Note 9 may encompass any feature on the part generated under the instruction. Note 9 is a general note falling under the initial heading above the notes "Unless Otherwise Specified". Note 17 is a flag note. Â Edited June 24 Link to comment Share on other sites More sharing options...
[Ed...] Posted June 25 Share Posted June 25 Would the .015 tolerance be treated like a dynamic profile? Link to comment Share on other sites More sharing options...
[Ri...] Posted June 26 Author Share Posted June 26 Please sign in to view this quote. Haven't thought of that, and I would not know how to apply it in v2022. Is this a capability that v2025 has? Link to comment Share on other sites More sharing options...
[Ed...] Posted June 29 Share Posted June 29 I reread the dynamic profile section, and I don’t think my suggestion works for this part since the note says MAX and "MEASURED SURFACE". I think reporting profile with no datums and a unilateral tolerance zone in the + material direction would satisfy Note 17. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 7 Author Share Posted July 7 Please sign in to view this quote. This isn't clicking in my brain. If I do not use datums, then I am violating the required DRF. Link to comment Share on other sites More sharing options...
[Ja...] Posted July 7 Share Posted July 7 So I looks like they expect a very rough surface texture and they want a .015 band of surface variation ignored. If that's the case, then I think you want some type of data filtering to happen. 1 Link to comment Share on other sites More sharing options...
[Ed...] Posted July 7 Share Posted July 7 The way I was reading balloon 2101 is that the surface has the UOS and an "additional" requirement. The first requirement (Note 7) would be: PROFILE| .040 U .030|A|B|C The second requirement (Note 17) would depend on what "MEASURED SURFACE" means. If measured surface = nominal surface, then size and form would be controlled by: PROFILE| .015 U .015| to no datums. if measured surface = actual surface, then only form would be controlled by: DYNAMIC PROFILE| .015| to no datums. The surface would need to be inside both profile tolerance zones. 1 Link to comment Share on other sites More sharing options...
[Ja...] Posted July 13 Share Posted July 13 I was kind of thinking along the lines of Edgar, Where the profile callout is giving you more of a location reference and the note is giving you a form reference. Whereas if you were to think of it as a flat surface, the location of the surface needs to align within the main profile callout, but then no part of that surface can vary by more than the note almost like a .015 flatness Link to comment Share on other sites More sharing options...
