[Ri...] Posted June 24 Share Posted June 24 (edited) We may be getting into using PMI (Model Based Definition). Is anyone using this? Is there a STEP AP242 model available for training? Pros Cons Does Zeiss offer training? Edited June 24 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/ Share on other sites More sharing options...
[Lu...] Posted June 24 Share Posted June 24 Hi Richard, There is a PMI eLearning available. Learning Content: Identify basic requirements needed to create a PMI measurement plan Create measurement plans using PMI in ZEISS CALYPSO. Apply dimensional, form and location tolerances on a PMI program LINK 3 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152117 Share on other sites More sharing options...
[Ma...] Posted June 24 Share Posted June 24 Please sign in to view this quote. I believe I was able to play around with PMI on the Zeiss Cad Cube model if you have that. 2 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152129 Share on other sites More sharing options...
[Ze...] Posted June 24 Share Posted June 24 The biggest problems I have with MBD is that you're relying on someone else to put the correct callouts on the model and you usually have to modify any auto-created feature strategies anyway. But then it's been a while since I've looked back into the technology. 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152135 Share on other sites More sharing options...
[Ri...] Posted June 24 Share Posted June 24 No STEP242 version available, but you can use the cadcube_PMI-named.sat file. 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152141 Share on other sites More sharing options...
[Ri...] Posted June 24 Author Share Posted June 24 (edited) First draw back I see that you can't rename the PMI entities prior to creation. Zeiss should add a dialog box to enter the characteristic name prior to creating the characteristic. The pmiData.pmi file appears to be an xml file. I can edit the PMI file and rename characteristic names, not sure of the effect on tolerances and related features/characteristics yet. Don't mind my ramblings, I am searching for methods of characteristic creation that follows my characteristic naming scheme. Edited June 24 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152153 Share on other sites More sharing options...
[Ch...] Posted June 25 Share Posted June 25 A CAD converter is required to read CAD models that contain PMI data. A direct interface such as CALYPSO CATIA V5/V6 or CALYPSO CREO (depending on the database) is recommended. The CALYPSO STEP interface is now also possible (from version 2021). However, data information is often lost when reading in via the STEP interface. I only have Calypso 2020 💩 so I can´t use this tool. 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152171 Share on other sites More sharing options...
[Na...] Posted June 26 Share Posted June 26 Hi all, there is also a free webinar: PMI in metrology It is not software specific and should give you a good idea of the whole process. Nanno 4 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152217 Share on other sites More sharing options...
[Di...] Posted June 27 Share Posted June 27 Please sign in to view this quote. Renaming the features makes no sense as it destroys the traceability in the MBD process. 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152245 Share on other sites More sharing options...
[Di...] Posted June 27 Share Posted June 27 (edited) And also a whitepaper is available for you to download. https://www.zeiss.com/metrology/en/c/pmi-in-metrology.html And for Creo Designers we offer a CAD training for MBD as well Edited June 27 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152247 Share on other sites More sharing options...
[Ri...] Posted June 29 Author Share Posted June 29 Please sign in to view this quote. It makes a lot of sense when you go from reports like mine, to reports that could come from a PMI part. Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152265 Share on other sites More sharing options...
[Di...] Posted June 29 Share Posted June 29 Then maybe, if PMI becomes more important, a naming convention could be agreed on, so that there's no difference between the reporting and the naming in the PMI file. Nevertheless all customers that I've spoken with want to keep the traceability therefore they either use the naming that comes automatically when you create features in the CAD-software or they have special naming schemes defined in design and metrology so that no changes are required. Ideas for such a scheme can be taken out of ISO 7499 and ISO 7533 Hope that helps. Best regards Dinko 1 Link to comment https://qualityforum.zeiss.com/topic/26875-pmi-is-there-zeiss-training/#findComment-152267 Share on other sites More sharing options...
