[Ri...] Posted 10 hours ago Share Posted 10 hours ago (edited) We may be getting into using PMI (Model Based Definition). Is anyone using this? Is there a STEP AP242 model available for training? Pros Cons Does Zeiss offer training? Edited 10 hours ago Link to comment Share on other sites More sharing options...
[Lu...] Posted 9 hours ago Share Posted 9 hours ago Hi Richard, There is a PMI eLearning available. Learning Content: Identify basic requirements needed to create a PMI measurement plan Create measurement plans using PMI in ZEISS CALYPSO. Apply dimensional, form and location tolerances on a PMI program LINK 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 8 hours ago Share Posted 8 hours ago Please sign in to view this quote. I believe I was able to play around with PMI on the Zeiss Cad Cube model if you have that. 1 Link to comment Share on other sites More sharing options...
[Ze...] Posted 7 hours ago Share Posted 7 hours ago The biggest problems I have with MBD is that you're relying on someone else to put the correct callouts on the model and you usually have to modify any auto-created feature strategies anyway. But then it's been a while since I've looked back into the technology. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 6 hours ago Share Posted 6 hours ago No STEP242 version available, but you can use the cadcube_PMI-named.sat file. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Author Share Posted 5 hours ago (edited) First draw back I see that you can't rename the PMI entities prior to creation. Zeiss should add a dialog box to enter the characteristic name prior to creating the characteristic. The pmiData.pmi file appears to be an xml file. I can edit the PMI file and rename characteristic names, not sure of the effect on tolerances and related features/characteristics yet. Don't mind my ramblings, I am searching for methods of characteristic creation that follows my characteristic naming scheme. Edited 4 hours ago Link to comment Share on other sites More sharing options...
