PMI - Is there Zeiss training?
We may be getting into using PMI (Model Based Definition).
Is anyone using this?
Is there a STEP AP242 model available for training?
Pros
Cons
Does Zeiss offer training?
Hi Richard,
There is a PMI eLearning available.
Learning Content:
  • Identify basic requirements needed to create a PMI measurement plan
  • Create measurement plans using PMI in ZEISS CALYPSO.
  • Apply dimensional, form and location tolerances on a PMI program
LINK
  • Like! 2
The biggest problems I have with MBD is that you're relying on someone else to put the correct callouts on the model and you usually have to modify any auto-created feature strategies anyway. But then it's been a while since I've looked back into the technology.
First draw back I see that you can't rename the PMI entities prior to creation.
Zeiss should add a dialog box to enter the characteristic name prior to creating the characteristic.
The pmiData.pmi file appears to be an xml file.
I can edit the PMI file and rename characteristic names, not sure of the effect on tolerances and related features/characteristics yet.
Don't mind my ramblings, I am searching for methods of characteristic creation that follows my characteristic naming scheme.
A CAD converter is required to read CAD models that contain PMI data. A direct interface such as CALYPSO CATIA V5/V6 or CALYPSO CREO (depending on the database) is recommended. The CALYPSO STEP interface is now also possible (from version 2021). However, data information is often lost when reading in via the STEP interface.
I only have Calypso 2020 💩 so I can´t use this tool.
Renaming the features makes no sense as it destroys the traceability in the MBD process.
