[M...] Posted June 25 Share Posted June 25 Dear all, we are facing the problem that in the Excel Report from Calypso the Actual values are missing. Everything else is availaible in the file (Nominal, Upper tol, ...) Has anyone else also had this issue in the past and give me a hint? Thank you for your support. Link to comment https://qualityforum.zeiss.com/topic/26889-missing-actual-values-in-excel-report/ Share on other sites More sharing options...
[Ri...] Posted June 25 Share Posted June 25 On my offline seat, my excel file refuses to populate anything other than header information. v2022 I have not been able to solve this one. I can take the same program and run on a live CMM and it all works as it should. Link to comment https://qualityforum.zeiss.com/topic/26889-missing-actual-values-in-excel-report/#findComment-152169 Share on other sites More sharing options...
[Ma...] Posted June 25 Share Posted June 25 Hello MT, disabled Macros within Excel are mostly the issue when no actual results are displayed. If you go into Options/Trust Center you can activate Macros as a first test. www.portal.zeiss.com/knowledge-base?id=1263814 Best Regards Marcel 2 Link to comment https://qualityforum.zeiss.com/topic/26889-missing-actual-values-in-excel-report/#findComment-152173 Share on other sites More sharing options...
[Ch...] Posted June 25 Share Posted June 25 This typically works in that situation - CALYPSO: Excel No Actuals 1 Link to comment https://qualityforum.zeiss.com/topic/26889-missing-actual-values-in-excel-report/#findComment-152177 Share on other sites More sharing options...
