[Má...] Posted July 2 Share Posted July 2 Hy! How can I create a surface profile inspection from surface points? A created a section and surface points but can not check them for profile. BR, Máté Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/ Share on other sites More sharing options...
[Jo...] Posted July 2 Share Posted July 2 Hi, you can directly create a section and check it. Do you need the specific points? Something similar was discussed here: Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/#findComment-152419 Share on other sites More sharing options...
[Má...] Posted July 2 Author Share Posted July 2 Hy! At the moment it is on a section but I would like to do it on a surface also but with given points. How is it possible in the software? Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/#findComment-152421 Share on other sites More sharing options...
[Jo...] Posted July 2 Share Posted July 2 try curve polyline Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/#findComment-152423 Share on other sites More sharing options...
[Ch...] Posted July 3 Share Posted July 3 Hi, regarding creating a SP (not a line profile) where the actual data are only a point cloud. One word in advance: you will still need a mesh based CAD. Surface Profile from Point-Cloud to Point-Cloud makes no sense. The following steps should be working. 1) Create your Surface Points on Actual Data 2) Create a Point Cloud based on these surface Points (Construct -> Point Cloud -> Discrete Point Cloud From Selection). Hint: To select single points please select them in the explorer, press the right mouse button and choose Select All Points From Element) 3) Create an Patch Compound on your CAD. 4) Choose measuring principle Fitting element (switch your target inside the measuring principle dialog to the actual Point Cloud created in step 2) 5) Create your SP as usual. Yes, it is complicated but this is not a standard workflow. To my understanding if you have mesh data it should always be the way to go to use all points. Using more points you will get more information and reliable results. 2 Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/#findComment-152431 Share on other sites More sharing options...
[Má...] Posted July 3 Author Share Posted July 3 Tricky, but absolutely working. Thanks! 🙂 Link to comment https://qualityforum.zeiss.com/topic/26925-surface-profile-from-surface-points/#findComment-152435 Share on other sites More sharing options...
