[sa...] Posted July 3 Share Posted July 3 When I inspect the surface profile in the first image, the obtained profile does not match the corresponding colour plot. Similarly, in the second image, the line profile does not match the trim line comparison. Why does this happen? Link to comment https://qualityforum.zeiss.com/topic/26933-surface-line-profile-not-match/ Share on other sites More sharing options...
[Ma...] Posted July 3 Share Posted July 3 What settings you have to show deviations and colors? Select profile and on right panel open Properties -> Display - show color deviation representation. Now select from center of tolerance. It should show correct deviation numbers as profile sees it. Link to comment https://qualityforum.zeiss.com/topic/26933-surface-line-profile-not-match/#findComment-152447 Share on other sites More sharing options...
[sa...] Posted July 4 Author Share Posted July 4 Please sign in to view this username. Thanks for the reply, but I am using the same method. Link to comment https://qualityforum.zeiss.com/topic/26933-surface-line-profile-not-match/#findComment-152453 Share on other sites More sharing options...
[Ma...] Posted July 4 Share Posted July 4 (edited) OK, then you want to get MIN and MAX deviation from all points of that profile - now you will see where it is. Because value of profile is doubled the worst deviation. Edited July 4 Link to comment https://qualityforum.zeiss.com/topic/26933-surface-line-profile-not-match/#findComment-152455 Share on other sites More sharing options...
